what is the worst cable you have stripped? | Page 3 | on ElectriciansForums
Discuss what is the worst cable you have stripped? in the UK Electrical Forum area at ElectriciansForums.net
USA
stripped some about 5 X 5pair version of this
[ElectriciansForums.net] what is the worst cable you have stripped?
swa is fine, the stuff we stripped though was like the one about but it took longer to get rid of the screen because it was tapped as well than the strip and terminate the gland
can't find a picture of the cable as they were existing so i don't know exactly what they were (control wiring)
it had a blue sheath though
Even Google blushed when I tried getting a translation on there
Sorry its 'phonetic' as in spelt completely illedgedly but if you said it as written, so to speak, to an attractive young Lady in Praha, she would probably smile and commend your language, at worst slap you, at best do as you are asking & kiss you
it means " give me a kiss, please"
The worst cable I have ever stripped is a cable known as ALPEX it is a 3 core aluminium cable with aluminium neutral strands in a waveform pattern so it can be stripped down live the neutral strands lay on a rubber bedding underneath the PVC sheath and it can be an absolute nightmare to strip as the rubber bedding can stick to the cores and it's even worse in the winter months when you can't feel you're hands. I prefer to strip down the old PILCSTA cables (paper insulated lead covered steel tape armoured). We get a lot of neutral faults on the ALPEX cable as all it takes is a hole in the PVC sheath and water gets in and as the neutral starands are aluminium over time in corrodes and turns to a powder and can cause some serious problems and can be cause a very dangerous situation.
PILC (paper insulated lead covered) with tape armours. Covered in pitch, oily cores or as bad if they are dry and the papers unravel. Time consuming and messy. Do it live to make it more interesting.
Worst cable i ever had to strip was an under-sea cable over at cable-junction,had to use a large great white and that only got keen after i beat it with me paddle.....didn't end well actually....
Nightmare!
out of interest, whats the procedure doing it live...? I've watched a chap do it, just can't get my head round it!!!
Rubber gloves with leather outers and face visor for starters. Depth set hacksaw for tape armours. Remove hessian/ pitch servings fit neutral bond on lead then using plastic hackknife remove lead sheath between bond. Remove outer papers and hope you have 4 cores ie you have not just opened an HV cable lol. Using insulated wedges separate cores, tape and cut. Tape ends and all safe.
This is is not to be used as an instruction as how to do it but is a general overview.
Yep, i can see that type of cable being a bloody nightmare too. Never stripped or terminated one, but have watched as an apprentice, a take-off joint being made to one those cables, which were the original factory estate cables. Our company produced it's own power, it had a fair sized power station on site, that fed back onto the grid during factory off peak times...
Reply to what is the worst cable you have stripped? in the UK Electrical Forum area at ElectriciansForums.net
We just left it as it was, again the customer didn't seem too bothered, dont think she wanted me digging any further.
