What is this bulb and how do I remove it? | on ElectriciansForums
Discuss What is this bulb and how do I remove it? in the DIY Electrical Advice area at ElectriciansForums.net
sosodef
London
Dear all,
would appreciate your help in identifying what this and how do i replace it with another one. As it won't unscrew clockwise or counter clockwise and doesn't pull out either.
Many thanks,
sosodef[ElectriciansForums.net] What is this bulb and how do I remove it?
It is either a G9 (230v) or a G4 (12v) lamp. Unless it is a unique part the glass bulb part should wiggle out.
Heat from halogen distorted contacts on lampholder making it stiff, but it should just pull straight out. No turning.
Reply to What is this bulb and how do I remove it? in the DIY Electrical Advice area at ElectriciansForums.net
Hi Avo Mk8 Thank you so much! Yes the bulbs fit perfectly I don't think they are much bigger. I could have bought a bigger rated LED driver but...
T
How do I remove the front cover from a Vent Axia extractor fan The model number is not shown, but I have attached an image of the model. There are...
talktalk
T
