What is this?? Not sure what it might be | on ElectriciansForums
Discuss What is this?? Not sure what it might be in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Colwyn Bay
Hi all
Just wanted to know what the attached might be. Its under my stairs and switched off but i dont know what it actually is. Any thoughts?
Thanks in advance :)
[ElectriciansForums.net] What is this?? Not sure what it might be
i know a spark in the bay.top guy. he'll happily check it out for you. pm me if this interests you ( but i'm out most of the day till around 4 p.m.)
OP; Is it actually off? The switch is in the on position. DON'T use your finger to test.
Has it possibly been a supply for a defunct central hot air heating system? 30A fuse but only 2.5mm cable
Reply to What is this?? Not sure what it might be in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You are correct that the white wire should connect to Neutral. Then the capacitor connects between red and blue (capacitor with twin tags on each...
That worked!!! Thanks again for all the help and responding so quickly. Really appreciate it!!!
