What is this part (that binds multiple wires) called and how do I remove it? | on ElectriciansForums
Discuss What is this part (that binds multiple wires) called and how do I remove it? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
looks like lead, so can easily be cut off . either that or cut the conductors.
Make sure the power is isolated if that's a mains voltage connection.
It's some type of crimped ferrule that makes a permanent connection.
As above make sure it's not live and cut it off. If you need to make a connection again use a Wago connector or an equivalent.
[ElectriciansForums.net] What is this part (that binds multiple wires) called and how do I remove it?
Reply to What is this part (that binds multiple wires) called and how do I remove it? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
That's just a standard timer switch. The 2 red wires to the timer are the switch contacts, the 2 blue wires are power to the clock. The 'orange'...
The white is the neutral. The black is hot to the light, brown is hot to the fan… (or other way round) I did this myself once, but it was in...
