What is this sound from the electricity panel? | on ElectriciansForums
Discuss What is this sound from the electricity panel? in the UK Electrical Forum area at ElectriciansForums.net
Can you describe the sound?
Is it like a vibration? A beeping? A low hum?
Is it constant or only when high loads are used?
Might be a loose connection arcing. Get an electrician to look at it as taking the cover off the panel is dangerous
Reply to What is this sound from the electricity panel? in the UK Electrical Forum area at ElectriciansForums.net
Ah - are you saying you are building someone else's design? That might relieve much of the burden. Do they give you engineering drawings and...
The cable is way undersized. If the voltage drop is detrimental to the installation I would make a mention of it as volt drop generally is not...
