What jobs need doing in your own house, then? | on ElectriciansForums
Discuss What jobs need doing in your own house, then? in the Australia area at ElectriciansForums.net
Rockingit
Mentor
Supporter
V.Nearly Esteemed
Somerset
Thought I'd lighten the mood a bit:
You know the one about the plumber with a dripping tap.....well, as Sparky's I reckon our own little lists of DIY are just as silly. Or is it just me?!
In my house at the moment there are: 4 x GU10's need replacing, a socket to finish plastering around, the lighting wiring in the loft to finish, a 3G lighting switch not fully screwed back as I need to replaster the wall, a PIR waiting to go in, an isolator to retrofit, etc etc....... hardly a good advert for mates and family!!
I did get up the ladder this afternoon and fit a new aerial though. Maybe I should write myself an invoice.
Hmm, where to start. The signal for digital TV feed to the kitchen has been on the blink for months. I have 2 laptops and a couple of tower PC's to sort out. One of my monitors is on the blink.
I have a light switch in the bedroom that has a slightly damaged piece of plasterboard on the top edge (barely noticeable, but I KNOW it's there). I have a non functional extractor fan in the en-suite. That's just the electrical stuff, don't get me started on finishing the flooring and finishing/decorating the en-suite.
Moved in four and a half years ago , still got to run supply's to every thing outside .
Would not be so bad but there are six different sheds totalling somewhere probably around 5-6 thousand square foot with a milking machine heat lamps for the pigs work shop and freezers all running off a extension lead trailing out of one of the back conservatory top windows !
I have dug / moled all the ducts in and even pulled all the subs to where needed but just can not be arsed to finish it .:8:
had a leak so had to take down lounge light due to water junction box been hanging for around 3 months now (shame), desperate for outside lighing and power for xmas lights this year also but time ticking on.
Well, that's a fair excuse. Mrs Rockingit threatened to get the local aerial man in (also a sparky) as I hadn't looked at the problem; I took the hint and got up my ladder.
Reply to What jobs need doing in your own house, then? in the Australia area at ElectriciansForums.net
