What jobs need doing in your own house, then? | Page 2 | on ElectriciansForums
Discuss What jobs need doing in your own house, then? in the Australia area at ElectriciansForums.net
Rockingit
Mentor
Supporter
V.Nearly Esteemed
Somerset
Thought I'd lighten the mood a bit:
You know the one about the plumber with a dripping tap.....well, as Sparky's I reckon our own little lists of DIY are just as silly. Or is it just me?!
In my house at the moment there are: 4 x GU10's need replacing, a socket to finish plastering around, the lighting wiring in the loft to finish, a 3G lighting switch not fully screwed back as I need to replaster the wall, a PIR waiting to go in, an isolator to retrofit, etc etc....... hardly a good advert for mates and family!!
I did get up the ladder this afternoon and fit a new aerial though. Maybe I should write myself an invoice.
2nd fix shower, fan and lights in new shower room. install UFH mat. fit PIR to soffit lighting. replace 8 way, front end RCD, CU with dual RCD unit. split 1 RFC into 2 radials as there's more spurs than blazing saddles. load of plumbing, tiling, wood butchery. then, after lunch, i'll................
I've got a list of jobs as long as my arm to do at home, here's a few from near the top of the list;
  • Borehole control panel corroded beyond repair....needs replacement
  • Irrigation pump has leaking mechanical seal....needs removing stripping and recon
  • Swimming pool pump very old and doesn't hold prime any more.....needs replacing
  • Electric gate motor gearbox broken, unrepairable needs complete new motor
  • Air conditioner in my home office has a gas leak somewhere obscure
  • Intermittant RCD trip when heavy rain...possibly borehole panel leaking but need to localise
  • Back-up generator AMF panel needs cabling and connecting and earth spike installing
  • Waste disposal in kitchen drips inside cupboard under sink
Christ I could go on all day.
I need outside lights as my bin shed is in darkness when I take the bins out, and I could do with some outside sockets. I've got the gear, but I don't wana do it as it's not my house, I only rent it.
I also need to paint 2 Walls where damp has struck.
In the process of building a man cave heaven. Only got as far as the concrete base. I know as soon as it’s finished the wifey will dump all her stuff in it, so I can’t be arsed to do anymore…lol.
just finished mounting tv on to chimney breast (at normal level I might add, why do people have it a foot from the ceiling?) set ps3 av receiver and sky plus into chimney opening, (not used of course) tidied all cabling going off to surround sound, fixed front speakers to chimney breast, Henry Died.... Do they havea thermal cut out???? I hope so.or new Vac required... GRR
Outside light that the wife has being moaning about for years will do it one day......Just finished kitchen only took me 4 months...quite quick by my standards. I am thinking about testing the house but bit worried about what it will throw up :46: Laptop that has needs a new charger and a format. I could go on, sure the wife and kids could put alot more to this list.
I hope you charged yourself at least time & a half? You can afford to spend all day in the pub then.
Electrically wise, nothing, but that's because I did a full rewire after I'd tried to burn my house down a few years back. The place is a dump though, my Mrs has a good claim on Britain's No 1 slob :-(
I take it your wife does not come on this forum or your one brave man
Rewired my place a couple of years back but want to get the place belled up. Run all the cable for the alarm (in star)....just need to get a panel and bellbox and passives etc...needs plumbing for the rads (an easy job as the ceiling`s down at the moment...then board out ceiling and plaster up, skirting boards and architrive etc so plenty on...its just having the time but as i am living at my mums at the mo`and my apprenticeship together with my college commitments has to take presidence just now......
henry very simple . either a broken conductor in the flex or new carbon brushes needed.
Reply to What jobs need doing in your own house, then? in the Australia area at ElectriciansForums.net
