B
blenki
Hi im having to replace some old meter cable from the meter to the consumer unit , as it is around 6m in length i am going to fit a switch fuse unit , my question is what type of 25mm cable would you use and will it need a separate cpc other than the main 16mm main earth that is going to be run to the CU,also how would you wire it in , there is a double pole switch there at the moment so isolation shouldnt be a problem. Many thanks
