What method do you use for fitting consumer units | on ElectriciansForums
Discuss What method do you use for fitting consumer units in the UK Electrical Forum area at ElectriciansForums.net
oscar21
Nearly Esteemed
North West
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and others that look like a work of art. But for me to get it looking even half neat I have to strip everything out of it so its just an empty box, strip everything back and mark the cables with a sharpie, 1 dash, 2 dashes etc, make off all the neutrals and earths and then put the din rail back in and start connecting the browns up.
This random photo seems to suggest he is stripping one cable back at a time and wiring each MCB up as it comes.
How on earth does he end up with a board so neat after doing it that way, if I did it that way it would look like a spiders web inside.
Reply to What method do you use for fitting consumer units in the UK Electrical Forum area at ElectriciansForums.net
    • Friendly
What is the distance from the point outside the house to the shed?
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
