View the thread, titled "What multi function test meter?" which is posted in UK Electrical Forum on Electricians Forums.
K
Kathir.Sris
Hi all,
I am attending a Competence in Testing course and that course requires for me to take my own test equipment. Can anyone kindly recommend a reasonably priced multi-function test meter that meets all the tests for 17th edition please?
Many Thanks
Pete, I already have Level 4 equal of C& G qualification and 17th edition C&G certificate. I have several years Electrical Engineering, Tel Com and IT infrastructure Engineering experience. Now want to come out of the stressful environment and go back to electrical work :0
You could hire one and see if you like it. I would say don't get a metrel. The leads are very non standard so any probs you have to replace the whole lead kit. I had a go with one of the top of the range ones and it is complex, unnescesarily so. I like simplicity with MFTs'
I have a Metrel and would never buy one again ;)
Everyone will have different opinions on which tester is best, and often the best one is the one with which they are most familiar.
Familiarity can be an advantage as it will speed up testing for you and help you avoid errors in testing.
Simplicity is a good approach as you will be using it often and having to adjust settings needs to be straight forward.
If you search for multifunction tester on this forum then you will find many threads discussing the advantages of different testers, however it comes down to your personal preference (and budget) in the end.
If you list out the tests that you will want to do and the functions that you are hoping to use, e.g. downloading data, bluetooth compatibility and so on and then look for the tester that meets those requirements.
Presumably your budget will also need to cover, multimeters, voltage testers, possibly a proving unit, and depending on your requirements, clamp meters, sound level meters, lux meters, fluorescent tube testers and so on, so it would be a good idea to assess all that your budget needs to cover so that you can then know how much is available for the multifunction tester and work from there.
Each to their own and everyone will have their own opinion...HOWEVER, the advice above about buying a good one and sticking with it is sound. I've had my Megger MFT for a few years now and it has never let me down. Not worth going cheap just to save a few quid and then regretting it until you can afford a replacement. Megger or Fluke for me. I used the Kewtech on a course a few years back and found it easy to understand (from scratch) but I don't think the build quality is as good ...
Reply to the thread, titled "What multi function test meter?" which is posted in UK Electrical Forum on Electricians Forums.
