What on earth was causing this? | on ElectriciansForums
Discuss What on earth was causing this? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
Today I had a routine socket change. The present one was tripping the RCD. The customer had used one of those double conversion sockets that utilise a single back box. I noticed that the right hand switch on the socket would not turn off.
I chased out and fitted a proper double socket. All tests were fine and the switch worked as it should. I then plugged the customers plugs back in switched them back on and thought I'd switch them off again just in case they still tripped the RCD for some bizarre reason. But, the right hand switch would not switch off.
I then changed the socket again as my new socket now had a faulty switch on it. The new switch was fine, until I plugged the customers socket back in and switched it on. As soon as the socket was energised by this particular plug the switch would become faulty and not allow itself to be switched off (just on the side that had this particular plug in it), even when the plug was removed.
I then got one of the sockets I had previously used and loosened the screws holding the socket together. The switch started working again (i.e allowing itself to be switched off), I tightened the screws back up and it was fine. However, the same thing happened everytime I plugged this particular plug in. I then chopped off the plug (it was an extension lead with 8 sockets on it and 2 USB slots), fitted a new one and everything worked fine.
Why would a plug do this this???
[ElectriciansForums.net] What on earth was causing this? This is the plug that was doing it. It has the correct BS number and all pins are normal size as I have compared them next to another plug.
I do get a bit long winded Midwest.. sorry!
Basically, when the plug was plugged into a socket and switched on, the socket would then not switch off, even when the plug was removed.
Thats all I needed to say really, isn't it :)
What's connected to the extension lead?
I had a socket at my parents place which supplied my computer gear. It sometimes ended up stuck in the on position which I believe was due to the inrush current causing the contacts to stick together. This happened numerous times before it eventually welded itself permanently in the on position.
Reply to What on earth was causing this? in the UK Electrical Forum area at ElectriciansForums.net
Thanks very much - again for your input. It is a moulded-on plug. The first thing I did was change the fuse - which looked, and no doubt (now)...
Thank you, what would be the advice for me to do in this scenario? I've also seen circuits tripped in past from other things such as 1500VA step...
