deancooling
Wanted to use a switched fcu outside the bathroom in t&e but then maybe some flex from that going into the bathroom under the bath for a whirlpool ?
Discuss What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
Actually this is a very good question. Reason I have wired a couple that had 2 16 amp supplys, one for the blowers and one for the heater. To be fair though they were considered large, the average whirlpool is 4 kw, also agree with hawkmoon and trev about ignoring the plumber and getting proper advice.Is the flex just suppling the pump for the blowers I take it there isn't a heater fitted as well.
Can you see why I gave you a bit of a bashing in the last thread now Dean when you were talking about a 10mm2 cable? good luck fella I am done here now, just be careful.The flex is connected to an ip rated box which has some components inside. this is where the supply is connected too. Board has 2 rcds covering 4 circuits each.
I know you can get heaters for whirlpool baths but didn't think they were no more than 1.5 kw and the pumps about 750w ( about 1 hp) now if your talking hottubs obvouisly thats a different beast altogether.Actually this is a very good question. Reason I have wired a couple that had 2 16 amp supplys, one for the blowers and one for the heater. To be fair though they were considered large, the average whirlpool is 4 kw, also agree with hawkmoon and trev about ignoring the plumber and getting proper advice.Is the flex just suppling the pump for the blowers I take it there isn't a heater fitted as well.
the exterior 8 birth spa's can actually require up to a 40 amp supply, the largest house one I have seen needed 2 16 amp supplys, usually a 4kw supply is adequate. It is unlikely a 13 amp spur will be adequate for Deans whirlpool, but you never know, hense the questioning he has had for the last 2-3 days lol.I know you can get heaters for whirlpool baths but didn't think they were no more than 1.5 kw and the pumps about 750w ( about 1 hp) now if your talking hottubs obvouisly thats a different beast altogether.
well maybe not, anyhow all ended peacefully.Not sure i deserved a bashing when only asking for advice. Thought i would take to a forum first to help point in the right direction. But thanks anyway
Reply to What other types of cables can be chased into walls? in the UK Electrical Forum area at ElectriciansForums.net
