What Polystyrene can do to PVC | Page 2 | on ElectriciansForums
Discuss What Polystyrene can do to PVC in the UK Electrical Forum area at ElectriciansForums.net
Norfolk
Took this photo a few days ago. Lots of cabling had been affected where several years ago the "cavity wall people" had blown insulation and it had found its way into the meter box.
[ElectriciansForums.net] What Polystyrene can do to PVC
I had to deal with some old 1mm T&E in a loft laying on polystyrene granules, and was so brittle and degraded that as soon as it moved even slightly the sheath and insulation cracked and dropped off in up to 2 inch long lumps. Worst I've ever seen!
all the cables i have come across that have been in polystyrene the cables are fine they have become stuck to the polystyrene but the coating it leaves on the cable just comes off like a coat of polish. is it something to do with the cold this far north that i dont have the problems you guys describe ?
Reply to What Polystyrene can do to PVC in the UK Electrical Forum area at ElectriciansForums.net
I can't help wondering about earthing arrangements and how important aesthetics really are when attempting to make the best of a less than ideal...
nicebutdim
N
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
