What regulation does L shape chase come under | on ElectriciansForums
Discuss What regulation does L shape chase come under in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
T
The Ghost
I am told a chase I did was dangerous and should never be done in this way. My thinking was considering all things it was in safe zones and is not dangerous. I would appreciate opinions on the matter please. The other part of the picture is where the client claims a scratched pipe when drilling through the joist and will have to have the pipe repaired. Again opinion would be welcomed. I could not go straight through due to obstructions above.[ElectriciansForums.net] What regulation  does L shape chase come under [ElectriciansForums.net] What regulation  does L shape chase come under
I am told a chase I did was dangerous and should never be done in this way. My thinking was considering all things it was in safe zones and is not dangerous. I would appreciate opinions on the matter please. The other part of the picture is where the client claims a scratched pipe when drilling through the joist and will have to have the pipe repaired. Again opinion would be welcomed. I could not go straight through due to obstructions above.View attachment 33696 View attachment 33697
Pipe repair, can't see any damage apart from a shiny mark IMO client is pulling a fast one apart from being a dilbert, pipe repair my ---
What circuits are running in the chase,? Could you not have created a zone by installing a socket vertically below where the cables were going up the celing.?
Your work is to regs no problem, however this may seem harsh but i would prefer to see a prescribed zone created or an alternative route found!
There is a stud work on the right hand side could you not of used that.?
Fair comment ! You would still have the problem of going through the 2' of brickwork above the stud partition requiring a chase. And would still have hit the obstuctions above in the loft, but yes I suppose I could have got around them if I really had to. But to my understanding it is in a prescribed or safe zone i.e. within 150mm from corner or ceiling
Reply to What regulation does L shape chase come under in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
