Hi, I've sent a private msg to you.
Would be happy to help you out but need more info.
Cant reply to your private message as i dont have enough posts????
Anyway here is the spec. I live in the midlands.
There are 3 bedrooms,kitchen,dining room,living room,bathroom and stairs and landing with a cupbord to house the boiler.
Bed 1 will have 6 LV recessed downlighters with 2 way switching.wall switch and pull cord above the bed. 4 twin sockets. 1 extra high level twin socket with an aerial oulet as we will be putting tv's on wall mounted brackets. we dont want Tv wires hanging down thw walls.
Bed 2 will have 4 LV recessed downlighters on 1 way switch. Ther is a cupboard in this room so that will need a batten lampholder and a 1 way switch outside of the cupboard door.3 twin sockets. 1 extra high level twin socket and aerial outlet. TV Aerial to be installed in loft with splitter/booster box.
Bed 3 will have 4 LV recessed downlighters with 1 way switch. 5 twin sockets. 1 extra high level twin socket and aerial outlet.
Hallway and landing will have 4 LV recessed downlighters on the landing with 2 way switching and 2 LV recessed downlighters at the bottom of the stairs with 1 way switch. Obviously this will be a 2 gang switch to control both sets of lights. 1 single socket. Switched spur for boiler cupboard and cable installed for boiler room stat. There will also be 2 mains smoke detectors on radial circuit
Living room will have 2 pendant light fiitings on two way switching. 2 wall lights on 1 way switching. 4 twin sockets.
Kitchen will have 7 LV recessed downlighters on 2 way switching. Also provide switching and cabling for kitchen cabinet lighting. 4 socket outlets. 1 radial circuit for the cooker outlet and 1 radial circuit for the fridge.
Dining room will have 1 pendant light fitting on 2 way switching. 3 twin socket outlets. Unswitched spur for the burglar alarm panel. Counsumer unit will also be sited in this room. Also install external meter box to house electric meter.
there is also a front canopy on the proerty which will require 6 LV recessed downlighters and PIR. Manual overide switch in hallway.
Please price this from a labour only perpective because obviously the specification of the fittings has not been decided yet and would be difficult for anyone to price.
