What should I charge to install a EV charger | on ElectriciansForums
Discuss What should I charge to install a EV charger in the UK Electrical Forum area at ElectriciansForums.net
Coventry
Hi I’ve been asked to quote and install a ev car charger on a domestic property as I haven’t quoted for one before and I usually do price work not day rate what would your recommend I charge it’s a fairly simple job as the main fuse is in the garage where the charger will be installed on the outside wall
Any help would be appreciated thank you
Forgot to mention that the client will be supplying the ev charger and new consumer unit
Reply to What should I charge to install a EV charger in the UK Electrical Forum area at ElectriciansForums.net
This was posted this week, on topic ....... https://niceic.com/newsletter/omission-of-overload-protection/?dm_i=7G1W,7GCE,K4L2A,WHET,1
Looking again the conductor coming from the lh fuse and the lh n appear to be in heat shrink as does the earth. Looks a bit 'home made' as though...
