What size are these tails | on ElectriciansForums
Discuss What size are these tails in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
West Sussex
Looking at PIR on a TT system. Noticed that the neutral tail is made up multistrands. Should have taken a photo. Does anyone know what size these are?
Cheers
Rich
You say its a TT, in that case it sounds like straight concentric. The neutral strands are bare and completely surround the live inner core, similar construction to swa.
Edit - Just noticed you said the individual strands are insulated, that would indicate split concentric which would normally be used for TNS or TNCS.
Reply to What size are these tails in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Well another week passed and I still don't have a proper answer to where the process is wrong. To reiterate, this is not a question for a real...
Once you have designed your switchgear layout, You could try, New Circuit engineering, Close Engineering or Blackburn Starling to manufacture for...
