Hi all,
Bit of a dilemma, hoping someone can help.
Im running a supply to a garden out building, from a 40 amp RCD protected type b mcb at the main board. The first 8 meters or so are in twin and earth and will be in plastic conduit, the second lot of cable is swa, clipped direct to an outside wall and about 20 m. The question is will 6mm cores through out be ok?
Depending how you work it, 6 or 10 are both acceptable?
M
M
