What size crimps | on ElectriciansForums
Discuss What size crimps in the UK Electrical Forum area at ElectriciansForums.net
the ones I used for the last job, Green ones but I cant find just those and I cant find even one to try and size it
grey gray gray gray 4mm .
This . Yet Ive seen people just cut them sort and not use a Ferrule
you could double the flex over ,but it would not show you are a professional spark ,the last inspection the idiot says those are nice .what biscuits or tea .
Ferrule kit and self-adjusting crimper in Lidl just now for ÂŁ15 or so. What not to like?
The colour tells you the ferrule size BUT there are two standards (at least) in use! Some RCBO have different flying lead sizes but likely going to be 2.5mm - 6mm range, strip one, see if it matches a ferrule, crimp said ferrule on and see if it holds.
Reply to What size crimps in the UK Electrical Forum area at ElectriciansForums.net
Went into an MCCB, terminated very nicely thank you very much, however it was just me doing some training with crimping. 'introducing extra point...
well then, must be a fault on the circuit, a faulty appliance if a power circuit or a faulty RCBO.
