Hi,
I have a three phase switch fuse supplying a 16A socket. In the specification provided it states the following:
Design Current - 16A
Main Protective Device 20A
The circuit is fed from a C20 MCCB at the distribution board.
What size of fuses should I be putting in the switch fuse?
16A or 20A?
Thank you.
I agree for a single point socket 16A. But it is suggested 20A can be used although I admit these things in GN1 are not necessarily Regulations.
Hi,
16A or 20A?
Thank you.
Op no mention of cable size, ccc is a main factor.
...20A is due to the fact a radial of more than one 16A socket can be employed ... however if the circuit supplies one 16A socket I see no reason to use anything above a 16A protective device.
Agree.
Apologies for my dumb question but why are there additional fuses being spec'd here? Local isolation yes, but it's already got a C20 at the board so shouldn't the question be "do I keep the C20 or go to C16?" :)
GB
What size Fuses do I require?
Gavin Millar,
Wilko,
