I have a 200 Main Panel in my basement. I want to put a 100 subpanel in my attached garage that would be about 75 feet away. The sub will need 1 220v circuit for my air compressor. 1 50 amp circuit for my hot tub. 1 40 amp for my air handler. And 2 or 3 circuits for misc. wiring. Can I do this and if so what size and type of wire will I need to run. Only the hot tub and air handler would ever be running at the same time. Thank you in advance....
