What sort of power do these wash loo's use? | on ElectriciansForums
Discuss What sort of power do these wash loo's use? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
The customer wants me to supply power in the bathroom for a 'wash loo'.
He doesn't know the exact one he wants but it will be something very similar to his partners, which he has sent pictures of. See below.
I wondered if I can use the lighting circuit as it will be the easiest way to get power, i.e come down from the loft, but I need to find a power rating first. Does anyone know what sort of power these things use?
I think they provide warm water, I'm not sure if this is plumbed or electrically heated. Also, I think it has some kind of blown air function, which I'm guessing may be warm, thus using a bit of power. Plus maybe a warm seat function.
Cheers all 😃
[ElectriciansForums.net] What sort of power do these wash loo's use? [ElectriciansForums.net] What sort of power do these wash loo's use?
The lighting circuit will be unsuitable, I'd say it'll draw around 1.5kW when heating water, maybe even a little more. So a FCU from a convenient ring or even 16a radial back to the CU if nearby as an alternative.
Edit - I do believe that some people have more money than sense - what's wrong with just giving your @rse a good wipe. It'll/should have a daily shower anyway. 😀
Cheers Dave,
I thought that might be the case, pity.
Completely agree, it's going to cost a fortune to get power there now, just to have a bit of warm water on your bum!
Good of you to reply after I took the mickey 😄
From the Clos-o-mat installation instructions:
220-240V single phase AC supply is required, (loading 4.5A-4.9A, maximum power 1300 watts). The Closomat toilet is supplied with a 3 core cable attached and MUST NOT be removed or replaced. A 10A fused spur is required for isolation.
Reply to What sort of power do these wash loo's use? in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
Hello oscar21, When I wrote about cables heating up I meant that IF a cable heated up that heat could not dissipate correctly if the cable was...
