Sanke
Hi all
I have been trying to check my own system to identify whether it is TT TNCS etc and now have some concerns House is over 20 yrs old but has had an extension Meter etc is in garage To describe the wiring configuration I will describe the flow as best I can:
Distributors tails into cut out, then to meter
From meter to fuse board (rewireable BS3036 I think) via 100ma trip
From fuse board to house etc
Only earth wire I can see (single cable) comes from behind the fuse board and bonds to gas on supply side
I have found under the kitchen sink an earth cable coming from the wall and bonding to water mains pipe but cannot see where this reconnects with rest of the system
There is no visible earth terminal anywhere near the fuse board or within sight of it
Question From my basic knowledge this does not appear good. What earthing system have I got? What should I do to check/improve things?
