What tests and paperwork? | on ElectriciansForums
Discuss What tests and paperwork? in the Commercial Electrical Advice area at ElectriciansForums.net
bartkusal
London
Hi, haven't been here for a while.:waving:
Just a quick one, what tests and certificates needed, if installing a couple of circuits, 2A loads from the control panel in the plant room, it will be supplying boilers
Don't say its a full wack EIC , and if I am concerned only with circuits I am installing?
Al
An EIC for the work you are carrying out
Yeah, pretty much new, that this will be the answer, the only thing which is annoying is that you still need to go and figure it out with all the incomers to the building, earthing, bonding ( 22 bonding conductors on MET), sub, sub mains and so on.....uhh:33:
Reply to What tests and paperwork? in the Commercial Electrical Advice area at ElectriciansForums.net
I can imagine it just disappearing (loudly) under short circuit conditions, then the resulting blast/plasma etc. casing the busbars to flash over...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
