What to do when you can't get a fixing | Page 3 | on ElectriciansForums
Discuss What to do when you can't get a fixing in the UK Electrical Forum area at ElectriciansForums.net
T
tombrooker84
Hello Guys,
Recently completed the first fix on a small 2 bed house, as soon as you drilled to get a raw plug in, the brick just crumbled away (thats without using hammer setting and using a slightly smaller drill bit). What do you guys do, I've tried cutting bits of wood, but that is quite time consuming when you have a few to do. I was thinking perhaps quick setting concrete, bonding them in, or perhaps drywall adhesive. Any ideas?
Cheers
Tom
Still got half a 20kg bag of "fast set" from 7 years ago, its like the best filler ever, once its set its rock hard. The stuff for dot & dabbing.
it appears to be like the salt bag in the ocean, it never empties... Never goes off... For a budget beating solution I'd invest in a bag. And hang onto it for the next 10 years ( think it was probably only a fiver or so, from Kellaways in Stroud)
EDIT when I say never goes off, i mean the stuff in the bagcis as good as the day it was bought 7 years ago. Mixed up it goes off pretty quickly.
Reply to What to do when you can't get a fixing in the UK Electrical Forum area at ElectriciansForums.net
J
Riven Slate: use sand/cement or adhesive - is there a definitive answer Hi - my builders bedded 10-12 mm brazilian riven slate on a sand cement...
Jim Rickards
J
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
