What to do with this earth strip thing?? | Page 2 | on ElectriciansForums
Discuss What to do with this earth strip thing?? in the Talk Electrician area at ElectriciansForums.net
The sheath on my TN-S supply has a piece of that attached...
It's wrapped round and bolted, but also soldered to the cable sheath.
About the second hole from the cable, there's a piece of 16mmsq GNYE with crimp lug bolted to it, going inside the service head.
On the third hole there's a 2-inch relic of about a 6mmsq solid bare earthing conductor bolted to it.
But then my main earthing conductor is is 16mmsq onto a BS951 onto the cable sheath adjacent to this lot.... Ze 0.08Ohms.
Simon.
I must have used miles of perforated copper tape years ago. It was available in 3 grades I think the largest being 1” X 1/8”. It could be plumbed to the sheath of paper lead cables. I don’t know why it went out of favour, it was great for trunking / tray installs. I used to run it unbroken the full length of the install.
seen some on an old job a couple of years back. was head scratching when i couldn't get a sensible Ze from the earth bar in the CU. turned out there was no continuity between the earth bar and the steel enclosure.
Reply to What to do with this earth strip thing?? in the Talk Electrician area at ElectriciansForums.net
R
Welcome to the forum - dont forget to log in next time!
By retired electrician, I mean that I have retained my ticket but no longer do installation work. Thanks for the clarification. I missed that it...
