What to do with two additional red wires when using newer light fitting? | on ElectriciansForums
Discuss What to do with two additional red wires when using newer light fitting? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Bristol
I am changing a light fitting and have excess wires. I’ve matched up the three core wires for the feeds I have but have two additional red wires left (pic included).
What do I do with these? Just tape them off separately? Or should they be inserted somewhere?
Thanks in advance for any help! (I think the complexity comes from old wiring being used for a new light fitting)
[ElectriciansForums.net] What to do with two additional red wires when using newer light fitting?
Means he's posted the same thing twice.
Put the two reds together in a connector block and put insulation tape around everything to avoid anything accidentally falling into or touching the screws or connections
Are you certain the wires correspond to L .N. E at the lamp end?
Pretty certain yes - I matched the colours and everything seemed logical and made sense.
Thanks for everyone’s quick responses - I’ve just ordered some connector blocks from amazon so will wait until they arrive before I complete the job.
Reply to What to do with two additional red wires when using newer light fitting? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Any professional forum member in or near Somerset help out? Needs a little more help than we can offer from afar.
Thank you so much for your help with this light work perfect now thank you again much appreciated
