poundland led head lamp, you can use it as a torch also.plus youcan press the button and it flashes on and off for parties etc.
next on my list is a cable tracer and a set of rods (as aparently it's not the done thing to use capping)
If your're doing Domestic a good lump hammer (wickes with the grey fibreglass handle is cheap and easy to use a lot of other makes are more like a short stick with a brick on the end) and a scutch chisel found at most wholesalers or building supplies.
or if Commercial /Industrial
a good quality Hacksaw and set of box spanners or normal spanners would be a good start
(ps the combination square for those who don't know has a steel rule and you use one of the attachments at a time, one is a centre finder ,a set square and a protractor)
Nope, no analogy, no inuendo, I mean literally folding paper. It seems pretty accurate, but that's just why I hate it I think, it's not precisely accurate! I'm OCD like that lol
do two folds then, then its as accurate as you make it.
got shown a trick the other day though where you dont need to use 45o's when fabricating tray. two cuts then sqweese sides in, fold to desired angle and bolt into place.
then get tin snips and two cuts and its quite neat
if you get a hacksaw go for 24tpi blades, if you go for 32tpi it takes forever to cut unistrut
The harder the metal,, i.e. steel, the smaller the tooth pitch. Softer metal needs less tooth pitch, otherwise the swarf clogs the blade up
I got shown to use paper when i was an apprentice, wow i forgot about that, funny the things you forget lol. Handy when doing some odd angle inbetween 90 and 45, not invested in a propper tool like i should of, or bolt two hacksaw blades with a M4 brass nut and bolt haha to get out the ---- :P
What tool next
Electrical Tools and Products
addi564,
Hobnob,
