What type of ADS is used for Short Circuit/Overload? | on ElectriciansForums
Discuss What type of ADS is used for Short Circuit/Overload? in the UK Electrical Forum area at ElectriciansForums.net
M
MattyH
I am at COLLEGE by the way, if your about to say join another trade or something lol. Also does RCD only operate if there is a earth leakage?
That would be an overload protective device, such as a fuse or MCB.
Yes RCDs only operate on earth leakage/earth fault.
A device that provides both overload and earth fault protection is known as an overcurrent device.
Such would be a fuse, MCB or RCBO.
As above but
an RCD will operate on any difference between Live & Neutral currents through it.
The difference can be when current from live conductors is passing to earth,
or from one RCD live bus-bar to another RCD Live bus-bar,
Reply to What type of ADS is used for Short Circuit/Overload? in the UK Electrical Forum area at ElectriciansForums.net
those old mk rcds are very fast the figure you have quoted is the maximum allowed not the typical times,I have seen mk ones trip at 9 ms , the...
2 3
