What type RCD when PV on system? | on ElectriciansForums
Discuss What type RCD when PV on system? in the UK Electrical Forum area at ElectriciansForums.net
South east
Hi all.
Try to keep this nice and short.
Had an EICR fail on a health centre due to corrosion on main supply which was causing high Ze values (DNO not interested in changing the supply).
Option is to install earth rods and change main switch to a time delayed 300ma 4 pole RCD main switch.
Question is….due to 3 phase PV being on the system would you recommend the main switch RCD to be Type A or Type B?
Many thanks
Reply to What type RCD when PV on system? in the UK Electrical Forum area at ElectriciansForums.net
Regarding the EV, it’s an Ohme charger which I believe has a type A RCD built in, setup would be: 50A RCBO to feed garage db Garage db has no...
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
