What would happen if? | Page 2 | on ElectriciansForums
  • Thread starter markthespark
  • Start date
  • Replies 27
  • Views 4K
Discuss What would happen if? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
yep sorry it just blows i did it the other week when not concentrating.
sorry to dissapoint but no big bang or anything just didnt work.
Once (not so long ago in a place not to far away) i watched someone blow the Fudge out of a timed SELV fan controller! he was connecting it all up, but some how he managed to put the perminant live, and neutral in the 12v side, and he went to turn the power back on the test it, and it didnt like it (well much!!) you know why i know this, because it was me!! lol
Never tried it on a larger transformer but I'm sure it's only blowing the output fuse because it is now an input fuse.
I've (seen it)done it to smaller tx's using batteries and flipflops( no, not those) to "defend" property (ahem)
I tutted very loudly when I saw him (before the Disgusted of Dagenham brigade, let rip)
Bit like a cross between a cattle fence and a cattle prod. Not something you grabbed twice.
Dont quite agree with the resistances side of things. Obviously we are talking about impedence rather than resistance
And Xl = 2 Pi FL
the L is fixed for the coil, and the frequency hasnt changed. Therefore the Xl of the coil is the same, regardless of which V we apply to it. Obviously the I drawn will relate to the V applied, and the Xl of the coil will mean it will draw whatever I it needs. The coil MAY be able to handle this, it may not, depending on the VA rating of the tranny
It isnt 'automatically' going to blow!!!;)
This thread is over 3 years old, but just in case students or apprentice are reading this...
This is utter tosh, most transformers have two or more windings (unless it's an autotransformer), lets consider the case in question. One primary winding and one secondary winding, the impedance of the windings in this case are likely to be different, because the inductive reactance and the coil resistance are different for each winding as they are wound from wire of differing CSA and number of turns wound.
The insulation of both windings will be rated and flash tested appropriately for 230Vac namely at 2300Vdc. If the primary and secondary are swopped so the former 12Vac secondary is supplied as a 230Vac primary, the former 230Vac primary now tries to become a 4408Vac secondary but the winding insulation quickly fails destroying the winding and possibly the other winding and the former their both wound on, until the point where the circuit protection breaks the primary supply.
If the "transformer" (really a switched mode voltage converter) was of the type used often for ELV lighting and fans. With 230Vac applied to the former 12Vac output of the converter, the output circuit protection devices would fail instantaneously due to over-voltage, rendering the "transformer" dead scrap.
In theory 4370V. But the 12V winding impedance would be so low that you’ll be struggling to see through the smoke to read your meter.
simmilar happens when connecting a 12v halogen lamp to 230v. you can't see through the broken glass. maybe that's why manufacturers put a voltage rating on equipment.
I suspect that the electronic switchers would disconnect before anything serious happened. But a toroidal or double wound transformer would certainly give you a belt.
For continuous use you would need to limit the current flow through the primary winding to stop it from overheating and catching fire.
I heard that once a transformer catches alight, you then have to bury it in sand or fill the room with halon gas because you can't put it out. Mind you, I knew a woman once who could fill the room with a gas that could put you to sleep permanently.
Can confirm it doesn't last very long and does trip MCB, did it myself in a daft moment, the best bit was it was only accessible by a nice crawl through a gulley amongst some fibreglass. Needless to say I was pretty chuffed with myself :)
Reply to What would happen if? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
Only the N side of the lamp would be at 0v if you went further along the element the voltage would rise.
