WHats caused this ?? | on ElectriciansForums
Discuss WHats caused this ?? in the Australia area at ElectriciansForums.net
thats what i think but would that cause the burning ?
the socket was under a single oven in a oven housing possibly too close to the oven body, i removed the socket and replaced with a chocbox and 15A strip connector the socket was supplied via a fused spur.
Possibly the heat from the oven:confused:
Can i query if you have put the choc box and connectors within the same confines as the socket was with possible high temp' issues, if so your choice of connection may not endure the ambient temp' when oven in use.
no offence taken
what have you seen done before darkwood ?
Refering to less than safe solutions to everyday electrical problems, but 20yrs worth of following bad workmanship means the list is endless, alot of people out there especially in the years gone by chose to do quick job for fast buck, luckily thats getting ironed out of the trade now its just the persistant cowboys and the diy enthusiasts now.
Reply to WHats caused this ?? in the Australia area at ElectriciansForums.net
In the picture of the socket, it looks like one of the neutrals may have been screwed in over the insulation. Therefore, the live may also have...
It looked like the live connection side ( internally) burned against the neutral of the main switch
