Whats involved with replacing damaged solar panels/inverter. | on ElectriciansForums
Discuss Whats involved with replacing damaged solar panels/inverter. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
oscar21
Nearly Esteemed
North West
We do a fair bit of work for insurance companies repairing/re-wiring flood and fire damaged properties. the one I looked at today has solar panels on the roof and an inverter in the loft, the house has had a fire. The panels and the sort that fasten directly to the roof laths with a flashing kit so they are quite literally toast now. The inverter has seen better days also.
[ElectriciansForums.net] Whats involved with replacing damaged solar panels/inverter.
We are obviously re-wiring the place but what's the score with the solar side, can I replace everything or will it be classed as a new installation, its 4 panels on the roof and they were just connected together and then into the inverter with a piece of 2.5 down to the consumer unit. Inside the CU was a 16A rcbo and a mini kWhr meter next to it. Not got a clue as to who owns what at the minute.
The manager that met me there said maybe bung the cost of the solar course onto the job but I've just had a quick look at the MAPIT site and its all gobbledygook to be honest.
Your not telling me its hundreds and hundreds of pounds and months/years at college again just to fit solar panels is it? I thought it would be a one day course for about ÂŁ150 like a pat testing one.
MCS is the scheme you need to belong to to install PV, well it is not a legal requirement but if the PV array isn't installed by a MCS accredited installer then it may cause the home owner problems with regards to such things as selling to the grid applying for government incentives and also potentially if they sell their house later, amongst other things.
2 or 3 or 4 day course depending on the provider. NICEIC one is 4 days for instance.
Are you likely to install a lot of Solar in the future? or want to add it to your services? If so then it might be worth investing in the course and the MCS accreditation.
Install an isolator in a convenient location for the solar installers to connect to.
Solar is not difficult BUT like anything, if you are installing it for a job, you should at the very least be able to prove that you are competent.
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
Reply to Whats involved with replacing damaged solar panels/inverter. in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I think they are just asking for details of the install, including any calculations, such as max voltage and current checks. So yes the MCS PV...
Need to crack on to get most from this year :cool: BTW if you are thinking about adding to the strings later, i.e. add more panels to existing...
