What's the Banjo doing? | on ElectriciansForums
Discuss What's the Banjo doing? in the DIY Electrical Advice area at ElectriciansForums.net
Scotland
As a trainee can I ask why the banjo is on the outside of the Wiska box. I understand that the earthing of the SWA must be maintained but would having the banjo outside mean you need to drill through the IP66 box to connect to earth and by doing that are you not compromising the IP rating? I understand the earth locknut is inside the box so what function does the banjo have when it's outside the box and not connected to anything?
[ElectriciansForums.net] What's the Banjo doing?
It tends to act as a load spreading washer, allowing the nut to be tighter without the gland digging into the plastic of the box.
IP23 is arguably the minimum for a box mounted where that one is, so a little compromising of the IP66 rating is acceptable.
In that configuration, you would have to drill a hole and nut and bolt a fly lead to earth the armour.
The easiest way is to use an earth plate.
Thanks for taking the time to reply. I found this on an electricians youTube video and can't understand why he didn't use an pirana nut or earth plate like this?
Thanks for taking the time to reply. What I don't understand is why he put the banjo outside the Wiska box?
The banjo won't fit inside the Wiska, the inside wall is not flat. Normally I'd fit an earth bar inside that has a profile machined to fit.
See post #5. There are different earth bars available to suit different Wiska sizes, the '308 is the most common size.
Thanks very much to you and all who replied - that's answred it. I know what you mean by the Earth Clamp Bar for SWA.
You’ll never get a hammer and chisel in there to tighten it up…..
Sorry, wrong thread. 😂
There may be a situation where that particular banjo isn’t required at all. Whether it comes in the pack or not…. It isn’t always required.
Reply to What's the Banjo doing? in the DIY Electrical Advice area at ElectriciansForums.net
I assume said contractor is part of a Part P scheme (NICEIC, Napit, few others..) in which case complain to them. They'll investigate (in theory)...
If you get a length of conduit, and seal both ends then the IP rating will instantly be IP68!! If you buy an IP66 rated Wiska box it will...
