E
Edwardioo
at a job today and saw a plug pluged into a socket followed the flex and it went into the wall and was chased up the wall feeding 4 wall lights lol... Good Stuff!
Discuss Whats the best cowboy job you've seen? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
i have seen 6mm laid from the cu through a wall and then laid on the floor under carpets and floor runners up to the cooker outlet. oh and then it got better as they trimmed back all the cores and only used 2 as they could not get them all in
Only four wall lights! You have to do better than that.
How about a 9.5 kw shower wired into a lighting circuit with 1mm t/e. The guy was adament there was something wrong with the shower because it tripped everytime he switched it on.
Do you laugh or cry ??
i posted one on here last year, wher a double metalclad socket has been wire directly in to the incoming side of a switched fuse, no earth/cpc, and the RCD coming from the aforementioned switched fuse had been bypassed, feeding street lights on a caravan site.
Reply to Whats the best cowboy job you've seen? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
