Whats the best LED GU10 dim bulbs you use ? | Page 2 | on ElectriciansForums
Discuss Whats the best LED GU10 dim bulbs you use ? in the Lighting Forum area at ElectriciansForums.net
Again, Varilight V-Pro and either LAP dimmable GU10's, or Aurora Ice dimmable GU10s (if the client wants to spend a bit more, they kick out a bit more light per watt).
Incidentally, for the V-Pro modules, it works out cheapest to buy a 2-gang dimmer from screwfix (code 98455) and just take the modules out.
True !! . I also use to use Hamiltons .Expensive and super reliable. But not easy to get
While we are on the subject of led lamps, occasionally I come across situations where customers complain of a very slight flicker from their leds .On investigation I have not always been able to nail down the issue and end up suggesting we try a better quality lamp, which often does the trick. However it is frustrating when you don, t find out the exact cause of the issue. I wondered what you guys find to be the most common cause, s of led "flicker" and what are the most common solutions?
Adding a buffer can work ..
need a decent size wagobox.
Reply to Whats the best LED GU10 dim bulbs you use ? in the Lighting Forum area at ElectriciansForums.net
Sadly not very near Swindon! I'm in Oswestry. Thanks a lot for the thought though!
I've a few flush pirs fitted around the house Hallways , Kitchen , Toilet etc One of the best things I ever did The pir integrated into the...
