What's the best Voltage for a Drain Camera electric? | on ElectriciansForums
Discuss What's the best Voltage for a Drain Camera electric? in the Electrical Tools and Products area at ElectriciansForums.net
1/12 Metro Court, Gateshead, NSW
Hi
Forum, I had drain cameras plumbing equipment and tools, I was just wondering how much voltage the right drain cameras would have if we converted them to electric?
Admin Note - cannot link out until posted ten times.. Many thanks.. Lou
Any idea is much appreciated.
Here in the UK for site work outside we would typically expect to be using a 110v isolating transformer (if I'm not mistaken, these are 55v-0v-55v, the center tap being used as the earth for the equipment connected to the secondary side of the transformer, with no direct links between any part of the primary or secondary connections).
Given you'll be working with water, the real answer is as low as possible whilst still being feasible. I also don't fully know what the laws are about selling things like this, but I suspect there would be a lot more hoops to jump through if you start connecting them directly/indirectly to a mains derived supply. You certainly shouldn't think about just buying a switch mode power supply brick from some supplier on AliExpress or whatever it's called because these often have one side of the output connected to the input and really that's not acceptable for this kind of environment.
Personally, I would avoid this unless you have absolutely no other choice because it increases the complexity of any kind of certifications and also increases your exposure when it comes to potential claims that could arise as a result of injury or death if the power supply went south and the camera was suddenly live.
Do you mean you want to run these from a main adaptor/PSU rather than batteries?
If so, what battery type and voltage do they use currently?
Reply to What's the best Voltage for a Drain Camera electric? in the Electrical Tools and Products area at ElectriciansForums.net
My guess is that you'll need to have your existing re-jigged as you've probably got a separate consumer unit fed from the time clock side of your...
On a small generator I wouldn't want to risk using diversity as they are not quite as forgiving as a mains supply and can very quickly fail when...
