M
Mrgee
Hi, i have a fault on my lounge ring main, it works fine but failed the tests, i have discovered a cable passing through the back of one of the sockets has been cut which was part of the ring, what i need to know is how should this be correctly reconnected, there is enough cable to crimp or run into a connector block (of the correct rating) just didnt know which was the correct method, i am unable to run a new cable due to the plaster and decor, thanks
