Discuss Whats wrong with this pic in the UK Electrical Forum area at ElectriciansForums.net
Dunno never seen switch with no neutral so Dunno how to code this also rcd sometimes tripping on zs low 3lead test is neutral arrangements can cause that or earthing problem I put as earthing problem
QJust ask yourself is this issue immediately dangerous? Is someone in imminent danger?
or is there a potential danger? Could some one come to harm if some one does something?
ask yourself if the double pole isolator without a neutral is dangerous and how is it dangerous? Justify your coding.
I don’t like it, I think it’s wrong. just because I don’t like it and think it’s wrong doesn’t mean I can code it. I can’t just say it’s wrong. you have to give a valid reason why it is electrically wrong.
so what do you think? Does it need coding? And why?
The composition is appalling.Hi I just start job need help with description whats wrong wit neuralView attachment 90884
Are you a trainee doing an EICR.Ok so let me ask
Do I need neutral in 220v single phase ???
I say YES to close circuit so how that db work??? And is that dangerous
What's wrong with this db
And how do I rectify if this is dangerous
Why rcd TRIP??? On low3 zs some guaid where I can look and what to read so I can understand
Why is this matterAre you a trainee doing an EICR.
Why is this matter and can you help me or question me
Hes trying to help you there is no need to be rude. Clearly your electrical knowledge is extremely poor and you don't know what your doing from what I see so westwarda question is justified. You have turned to the people here for help, so why not accept it.Why is this matter
Reply to Whats wrong with this pic in the UK Electrical Forum area at ElectriciansForums.net
