What's your preferred floodlight brand? | on ElectriciansForums
Discuss What's your preferred floodlight brand? in the UK Electrical Forum area at ElectriciansForums.net
C19rta
Trainee
East sussex
I've got a job to replace three floods with 20w led pir with a manual override. We only really use Collingwood but I can't get them until mid next week which is a pain. Bonus with them is they are colour switching, struggling to find a similar product..
Any recommendations lads/lasses
Cheers
I only fit osram ledvance now and have never been called back to any of this brand.
We had 18 out of 20 100w ledvance floods fail within 2 years. Don't know about lower wattage ones but 80,100 and 200w are extremely problematic within replacements failing just as quick.
Lucky you, I've replaced most of the Ledvance ones I fitted, all from the original range 20W (2000 lumen) and 50W (5000 lumen).
Had no bother with Ansell floodlights so far
Might give them a go too, everything cef have been pushing recently seems to be rubbish, fitted a few Collingwood and jcc recently so will see how they get on.
I'm fitting Timeguard at the moment. Only had one major problem thus far but I suspect there is something else going on as I've had to replace the lights almost annually (previous ones weren't Timeguard, the failure of the Timeguard unit was the PIR module).
Do the collingwood floods have a 230v input for the manual override or is it the usual on-off-on procedure?
None of the led ones seem to have a 230v input
The Timeguard ones do, just done a mixed PIR and PIR with Remote install of two floods which supply the other in the event of movement or override via the remote.
Reply to What's your preferred floodlight brand? in the UK Electrical Forum area at ElectriciansForums.net
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
