When did neutral at the light switch become standard practice? | Page 2 | on ElectriciansForums
Discuss When did neutral at the light switch become standard practice? in the DIY Electrical Advice area at ElectriciansForums.net
Hello all,
I am in the process of buying a house built in 2002 and I am trying to find out when it became standard practice to run neutral to light switches. The reason being I may look at having smart switched installed and having this already in place would make the job so much simpler.
There is no way to determine this except take every switch off and check ..................
Testing the ring final circuit when both cpc’s at the board are covered by one piece of sleeving and they are twisted together!!!!
Arrrgggggghhhhhhh!!!
More of a eicr issue tho
There is another way. Drop the ceiling rose cover and count the twin-and-earth’s
Scrub that idea. I forgot about the old J701 joint box under the floor trick.
Take off the switches. Not a difficult job but please follow all relevant safety guidelines
Not all smart switches use a neutral. Lightwaverf being one example. So it might not matter
Am about 10 post later .i hate 3mm earth sleeving g on everything from single 1mm to squeezing it in section over a 3core swA . Does my head in buy a few different sizes and fit the correct one not just what you have left in the bag which is always 3mm
Ah, thank you all for your replies. It seems I will have to wait and see and then decide what is the best plan of action!
i can understand cpc ends being twisted to ensure all are well connected in the terminal (separate sleeving for each) but to twist the lotand put into 1 sleeve is ,IMO, criminal , same with twisting L and N solid core into a terminal. hate it.
Every so often, I find the round JBs with the CPCs round the outside of the box, twisted together.
Reply to When did neutral at the light switch become standard practice? in the DIY Electrical Advice area at ElectriciansForums.net
You were correct those are neutral wires, it worked! Many thanks
Hi all, I've been at this all night for a smart switch I've installed for exterior lighting for the house located in the eve's of the house attic...
