When it looks wrong.
So, went to look at a property for a landlord. In the bathroom there is an electric shower in zone1, but it's mounted approx 2 foot above the water line. The isolator pull switch is outside zone2. Oh and the circuit is rcd protected and on a separate 45a breaker.
My thoughts were....why would you fit a shower so low, it's about knee height when in the bath. Then I noticed all the disability aids. Has anyone else come across a shower mounted so low, and if so, can you suggest a reason why it should be.
The person could be a double leg amputee, or a wheelchair user or a vertically challenged person. My wife’s aunt (80 year old) who can’t stand for long periods has a built in seat in her wet room and the shower itself is sited much lower than a standard shower.
If you,or a family member had any condition or ailment,which required an adaptation to improve matters,then pending obvious safety thoughts...gonads to the regs :)
I can vividly remember a pals grandad,a proper old Irish character,who had set up a scaffold tripod,above his bed,with a dangling ships hawser with a knot,to assist him getting up and away...
The visiting medical help,always asked about it's security,and he always replied "It holds up thousands of tonnes of masonry,so,crack on..."
Paul228,
PEG,
