Where can get a 20 watt round led driver with a 12v output ? | Page 2 | on ElectriciansForums
Discuss Where can get a 20 watt round led driver with a 12v output ? in the Lighting Forum area at ElectriciansForums.net
The cheaper option comes really close though but at 18 Watts, they're just not gonna do it.
You get 3 of the little 18watt PSU's for your single purchase costing £7.50!
I intended to mean you put at least two of those supplies in each light fitting (ie giving you 36W of power) wiring each supply to roughly one half of the lamps in each fitting.
You would need to make two purchases (£15) and you would have 2 PSU's left over.
But if the wiring does not allow you to split the load like that, then obviously this is a non starter.
Sorry I wasn't clear!
From what I can glean from the net the wattage should be marginally greater or equal to the demand.
Yes absolutely correct!
Reply to Where can get a 20 watt round led driver with a 12v output ? in the Lighting Forum area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
This controller might do the job if you have single colour strip. You'll still need a power supply prior to this! Lots of additional features you...
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
