Where can I get 16mm external SWA Glands from... | Page 2 | on ElectriciansForums
Discuss Where can I get 16mm external SWA Glands from... in the UK Electrical Forum area at ElectriciansForums.net
Stripping outer fine same as I always do but when you look back up the rubber seal it's fully compressed to the point where the nut is as far as it can go and you can look down it along the cable thus there is no seal and you can see the wire. You can get a screwdriver through the compressed seal and wiggle it about. Wholesalers have ordered some smaller glands. They said all non metal elements of the cables is getting thinner and most people don't bother and just hide it with the rubber boot, not my style. Really weird as I've used 20s loads of times on 1.5mm2 3core SWA before and never had this issue, cable diameter must be less. It was a drum of 100m from BATT cables..
Stripping outer fine same as I always do but when you look back up the rubber seal it's fully compressed to the point where the nut is as far as it can go and you can look down it along the cable thus there is no seal and you can see the wire. You can get a screwdriver through the compressed seal and wiggle it about......
Are you talking about an SWA gland or a compression gland?
SWA [ElectriciansForums.net] Where can I get 16mm external SWA Glands from...
Compression [ElectriciansForums.net] Where can I get 16mm external SWA Glands from...
Reply to Where can I get 16mm external SWA Glands from... in the UK Electrical Forum area at ElectriciansForums.net
