Hi all,
I changed a consumer unit today in a top floor flat in a converted town house. Down at the intake position is a PME head. There is a 63A switchfuse for the flat then a 16mm T&E going up to the flat where the meter and consumer unit is. By the look of it the meter would have been downstairs at some point but now has been moved upstairs. I have always been of the opinion (correct me if i'm wrong!) that anything before the DNO's meter has nothing to do with me and that this is the 'origin' to which the installation I am working on connects to the supply. If that is the case then would that not mean that the supply to this flat is now effectively TN-S? I need to take the main bonding into consideration too as at the moment they are in 6mm taken from the CCU (which in turn has only got the 6mm cpc in the submain.) Obviously if this is still classed as TN-C-S then I will need to upgrade the bonding. What do you guys think?
