Hi,
I have a Baxi 105HE Instant of 2006 vintage (the one with the pre-heat utility). It is working PERFECTLY except that it seems to be losing system pressure - according to the dial.
Not being one of you guys, so I might be misunderstanding it, this means to me that the water I am putting into the system virtually every other day to top up the system pressure MUST be leaking out of the system.
My problem is that I cannot, for the life of me, detect any wetness at any of the radiators or any of the pipework anywhere in the house where that water is going - there should be something wet, somewhere, if there is a leak?
There must therefore, common sense tells me, be another reason for the Baxi 105HE Instant to be losing system pressure in the way mine is doing?
Help!
Help!
