Where to attach neutral/ground in breaker panel | on ElectriciansForums
Discuss Where to attach neutral/ground in breaker panel in the USA Electrical Forum area at ElectriciansForums.net
JoeXYZ
baltimore, md
Installing an over the range microwave, ran the (yellow) wire to the box, but where can I attach the ground and neutral wires? The one bus on the right is full, the second bus on the right is empty, but can I use it? Nothing else is attached to it.
  • [ElectriciansForums.net] Where to attach neutral/ground in breaker panel
If that’s is your main panel you can hook up the grounds and neutrals to any one of the bars. If it’s a sub fed panel the neutrals have to be isolated from the grounds
So if neutral isn't switched, then whatever the power company think about it, the electrons aren't going to be able to tell the difference between neutral and ground only combined to the point of entry of the service, and them being combined all the way to the distribution board, as in this case.
Reply to Where to attach neutral/ground in breaker panel in the USA Electrical Forum area at ElectriciansForums.net
Hurricane florida. I & several neighbors lost power. A few bought generators & hooked to breaker box. I just bought one too. Delivery soon. I also...
You were correct those are neutral wires, it worked! Many thanks
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
