Where to put sockets? | Page 2 | on ElectriciansForums
Discuss Where to put sockets? in the UK Electrical Forum area at ElectriciansForums.net
JLeague
Huddersfield
As part of a kitchen refit I am trying to work out where to put the electrical sockets for my freestanding appliances.
If I have the sockets directly behind the appliance then they will just out.
If I have them in the unit next to the appliance, I will have to get the back of unit cut out.
I will be having a grid switch installed, but that doesnt solve the problem of where I place the sockets.
Is there any other way where I can get the appliances to sit flush to the back wall but be plugged in thats still accessible?
Look at the rear of the appliances, where possible site the socket where you can obtain the greatest clearance. There might be an indentation rear of appliance. Most appliances not really an issue.
Washing machines, tumble driers etc have pipework and flexible waste pipes
That's a very good point.
Is it against regulation to have a socket recessed into the wall? I mean to have the socket set deeper into the wall if possible.
Have you put the worktops in yet? How much space have you in the kitchen?
I use 700mm or wider over washing machines etc. OK, it's more expensive, but it makes life a lot easier.
If that is too expensive, space the units and worktops out by 100mm or more and construct an upstand with facing to match the worktop, leaving tons of space for cabling etc.
The kitchen is narrow but long - galley kitchen. At the design stage, have the plans drawn and now looking at findins out as many issues before we start the actual work.
Standard worktops so 630mm deep I believe.
As Tel and I have both said, use a wider than standard worktop. 600mm are fine for integrated appliances.
630 or 635 are used, for example, by Ikea, as their "standard" size. 700 and wider are readily available.
Building out a "standard" size with a "dashboard" at the back gives you tons of service space and can take socket outlets etc if designed correctly, and gives a raised ledge for your spice bottles and ashtray...the top or lid can be retained with magnetic catches...it's the way forward!
Reply to Where to put sockets? in the UK Electrical Forum area at ElectriciansForums.net
As an aside. I have seen patress/sockets fitted upside down under kitchen units with an appliance plugged in. The sockets were firm and not moving...
It's nice when people box off a big blank canvas like this. Makes a change from being asked to perform the impossible and expecting cables be...
nicebutdim
N
