- Joined
- Mar 22, 2012
- Messages
- 153
- Reaction score
- 39
Evening all,
Long story short:-
My dad has just had an aftermarket parking sensor kit installed on his corvette, is there anywhere that you know of that I could get the wiring diagrams (legally please)?
So far as I can tell. . .
The rear sensors are okay (wired to reversing light), & only active when vehicle is in reverse. Beep, beep, beeeeeepppp, etc.
The front sensors appear to be on once the brake pedal is depressed (regardless of vehicle speed), is this normal?
I can only assume that this means the unit receives a signal from the brake light, & then starts a timer that will be quiet after a few minutes? The beeper is incredible loud, and i'm not convinced that the beeping should start every time the brake pedal is depressed - there has to be a better way.
I was hoping that maybe there is a signal that I could send to the rear of the car (where the unit has been installed), that only operates below (or above) a certain speed - perhaps a seatbelt warning alarm, or similar?
Thanks In Advance
Billy
Long story short:-
Thanks In Advance
Billy
