Whia Torque Screwdriver | Page 4 | on ElectriciansForums
Discuss Whia Torque Screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
I always find it strange when fitting a new consumer unit it recommends checking the factory terminations for tightness and they always seem loose. It's not surprising if they are using such low torque values that they tell you to check the factory terminations
Thought about purchasing torque screwdrivers a while ago but came to the conclusion that they are possibly more trouble than they are worth
It's why one of the manufacturers ask you to check all connections for tightness- even factory fitted ones. Presumably these have been torqued before being dispatched.
Torquing has it's place but is not infallible.
If the cable is stranded i always untwist it with pliers so conductors are straight and then connect, and i don't have to give it as much of a tug as others might have experianced, to make sure its tight.
Most things that are torqued up to a predetermined value are usually subjected to regular maintenance, how many maintenance visits have been done on domestic consumer units to check the security of the connections
With this in mind how many times using the as tight as possible system do you find when returning to installations years later do you find loose connections a few times doing PIR's I've recommended that all the connections throughout are checked having found some that are very loose
On one industrial site I worked years ago they had a factory shut down every couple of years and every termination and connection was checked in all the switch rooms and plenty of them needed tightening to get back to the torque value
I just looked at sets of these torque screwdrivers in two different wholesalers locally and C.K. ones came out £95. and Schneider ones at £96 with a retail of £206 !! and the c.k. ones are not at all insulated whereas the others are. My little counter monkey informed me that it is wholly illegal to NOT use them now and all Main D.P. switches must be 2.3 Nm and all Rcd's and Mcb's etc at 1.7 Nm whereas before I always tightened to a reasonable torque and pulled gently to make sure cables were securely connected. ?????
If anyone is still thinking about buying the wiha ones, wera have their own one coming out that has the torque setting adjuster built in so you don't lose the bloody torque setting tool. Gutted I bought the wiha ones now, this was at the beginning of last year mind you.
my AEG impact driver does the job quicker and better than any torque driver. broke a few MCBs though. LOL. :bomb:
I've had a set of Wera torque screwdrivers in our workshop for a while now, they adjust by hand within a certain range. To cover all the ranges I had to buy 3 of them, one covers 0.3-1.5Nm, one for 1.5-3.0Nm and one for 3-5Nm. (figures are approximate from memory) I have no complaints about them, they're easy to use and they've survived well with daily workshop use plus they've stayed in calibration.
I also can't visualise some of the SI units but all the equipment we use has torque settings given in Nm nowadays so having to convert into ft-lbs for my older 1/2" and 3/4" torque wrenches which is a real pain in the ---.
Are they VDE rated ones? I thought they were coming out in march :(
I have just bought a set of the Wiha 2872. Yes you have to set the torque for each setting with the supplied tool. The slim bits fit very easily in all the mcb/rcd's etc I've tried. By the by, the set I purchased from an online tool supplier, was faulty. I rang Wiha UK to seek advice, and they sent me a replacement free of charge through the post. Can't beat that for service.
Reply to Whia Torque Screwdriver in the Electrical Tools and Products area at ElectriciansForums.net
I would say it is more about the bits than the torque of the drill. I use high quality Fisch auger bits for drilling out mortices and peg holes...
FFS - popped it apart, found the same issue and thought I'd update... You guys were already there!
